Netonix Switch and Nanobeam issues
Moolawatana
Sat Nov 07, 2026 8:57 pm
I have many remote sites, running on solar power, installed monitoring stock waters. Each site has a Nanobeam or Power beam, NanoStation (for local wireless access), at least 1 G3Pro camera and at least one G5 Pro camera, a Control by web relay and a switch. I recently changed some old Edge switches to Netonix switches (WS6-mini).
And now the system is very slow and I can not log into some of the control by web relays. The STP priority at each site is 32768 and at Radio Hill (main AP) switch it is 4096. But, the Netonix switches weren't connecting they k
ept bouncing to other Edge switches (re MAC address) instead of the AP. Through help, I have sorted that out, but I am still having trouble with connection issues and latency. I still can not log into the Control By Web relay. As soon as I changed back to the Edgeswitch, all works fine.
I have sent a lot of information to Ubiquiti (support files of both switches, nanobeams, screen shots of information, etc) and they have suggest I also contact Netonix.
All equipment has the latest firmware installed.
As an example: Attached is screen shot of the Nanobeam at one site with each of the switches attached - no settings changed.
Also, I can not get the switches to save the time. I have them power off over night to save battery usage and power back on in the morning - when they come back on TIME IS NOT SET. I have to go into config, untick and save/apply the time box then re-tick, save/apply for it to save. I have it set to the the correct ntp.
Marks.pdf
(316.06 KiB) Downloaded 31 times
