v2.0.9 Bug Reports and Comments
Been thanked: 210 times
Wed Sep 30, 2026 4:30 pm
Click HERE to download firmware v2.0.9 - Released 09/30/2026
FIXED / CHANGED:
- Fixed undefined behavior caused by dash characters in the switch name.
- STP/RSTP/MSTP roles now display correctly in the web UI and CLI.
- Fixed STP/RSTP/MSTP instability when handling multicast frames.
- Management is now reachable through other VLANs — a Layer-2-only VLAN no longer blocks access to the switch’s management address through it.
- Port Link Bounce is now quick — it no longer holds the port down far longer than manually disabling and re-enabling the port.
- Fixed occasional false multi-gigabit spikes in the traffic graphs.
KNOWN ISSUES:
- IPv6 is disabled pending investigation.
- IGMP Snooping has been found to cause instability with STP, it has been disabled pending investigation.
- Enabling D-VLAN on a port can lock up the switch.
- If you have an OCP on a port try using a different port to see if it’s a bad port or the problem follows the cable.
- WEB UI issues when not at 100% Zoom on browser, especially on the VLAN tab.
Released 09/30/2026
