Interesting repair
konspiracy
Interesting repair
Mon Aug 24, 2026 2:30 pm
Was going through some of our 24 port switches that are no longer under warranty. Swapping boards and stealing fans for use elsewhere in the network. Came across this warranty repair. No clean up of the board, no glue to isolate the repair or keep it from touching anything else.
Julian
Been thanked: 10 times
Re: Interesting repair
Thu Aug 27, 2026 5:05 pm
my records show you had that serial repaired at ISP technologies in march of 2024. You'd be surprised how small of a world this truly is; you didn't have -me- warranty that, sir.
It's not -terrible- work, but it's not mine -- *grumpy twidget noises*
thomas
Been thanked: 4 times
Thu Aug 27, 2026 6:10 pm
funny enough those jumper wires don't look like mine either, I use .2mm red enameled wire and tack it down with clear UV solder mask, like in the picture below.
https://groundedrepairs.com/gallery/photo8.jpg
not that that matters though, for a run that small, those wires aren't going anywhere and really don't have any need to be tacked down assuming they are enameled. I imagine the flux used is also no-clean flux, and there isn't any reason to clean it off other than aesthetics.
what's funny is that my units have a full 2 year warranty that includes fans, so that entire unit itself was likely under warranty when it was pulled from use
Users browsing this forum: Google [Bot] and 154 guests
