L2 Gratuitous ARP broadcasts
Flo
Been thanked: 11 times
Sun Jul 12, 2026 8:52 am
Hey there,
I have observed that our Netonix switches kinda flood the L2 Network with 3 "Gratuitous ARP" broadcast packets every 10 seconds.
Seems this behaviour has been hardcoded into /usr/bin/monitor:
Code: Select all
...@switch-..-199:~# cat /usr/bin/monitor
#!/bin/sh
date +%Y > /tmp/current_start_date
while true; do
  #Perform gratuitous arp broadcast to update neighbors
  arping -U $(ifconfig | grep -Eo 'inet (addr:)?([0-9]*\.){3}[0-9]*' | grep -Eo '([0-9]*\.){3}[0-9]*' | grep -v '127.0.0.1') -c 3
 fi
 sleep 10
done
Is there a technical reason why the switches kinda aggressively ARP themselves 3 times every 10 seconds, causing some background broadcast noise when running a few dozen Netonix devices on a network?
Re: L2 Gratuitous ARP broadcasts
Tue Jul 14, 2026 12:51 pm
3 arp broadcasts every 10 seconds is a flood?
Just think how many BPDU packets are flying around with RSTP.
I think I remember why we did this but it was a long time ago, so when i get a chance I will confere with Stephen.
Pretty sure it is needed otherwise your wating on mac entries to expire when there is a toplogy change.
Even if someone was running a HUGE flat network with 100 switches, which is not a ver good or wise idea, your not talking any significant amount of traffic.
Tue Jul 14, 2026 2:30 pm
Yea, so i checked with Stephen, i asked him to put that in back in 2019.
It solves the problem i expressed above when swapping out equipment standard arp or mac table entries TTL is 5min.
This insignificant traffic does nothing negative but insures a more accurate mac table and faster acknoledgment of equipment changes.
It was very pronounced when we serialIze switches and swap out a new switch at same IP but now has a different MAC.
I had also seen it when swapping out a switch at a tower it took time for local layer 2 equipment seeing the replacement.
Again compare this traffic to STP LACP Loop Protection or many other protocols in layer 2 not even talking about layer 3 protocols like OSPF and alike.
Very insignificant amount of traffic.
Users browsing this forum: Google [Bot] and 155 guests
