I've had two instances where I've attempted to take the backup config from a switch running 1.5.26 and restore it to another switch running 1.5.26 and the switch GUI becoming mostly unresponsive. Attaching screenshots of the mostly blank GUI. If I try to change any of the configuration I get a "Invalid Fields" error.
For what it's worth, both instances have happened when I'm moving a config from a smaller (less ports) switch to a larger one. The last instance was a config from the older WS-10-250-AC to a WS-12-250-AC. I can default the switch and GUI will act normal again.
Anyone experienced this? My work around has been to default the switch and manually redo the config via GUI...
Backup and Restoring config on 1.5.26
- CrackerRiley
1 post
Users browsing this forum: Google [Bot] and 139 guests
