WS-12-250 DC Power Cycling on LiFePo Batteries
joecrowley
Thu Jan 08, 2026 8:15 pm
Please help:
I have tried to power on two separate and brand new WS-12-250 DC by connecting them directly (with a 15A Circuit Breaker) to a 24V 100Ah LiFePo battery.
Fans will spin up, closed circuit voltage (read via multimeter) stays put. Power light comes on, and it may stay powered on long enough to boot up the http server and log in, but around that time, the switch entirely reboots itself. This is an ongoing cycle. The switch is running the latest firmware.
Any ideas? We suspect something is happening in the switch where it is not happy with the supply voltage for some reason or another.
Appreciate it,
Julian
Been thanked: 10 times
Re: WS-12-250 DC Power Cycling on LiFePo Batteries
Sun Feb 08, 2026 8:40 pm
LiFePo's are not like other batteries - V can't sag much, otherwise burny burny achy breaky, they have whole circuit boards in them to keep the lithium from the rapid oxidation it so desperately craves- switch may not actually be drawing enough to register on the battery's controller and it's going to sleep? I know they're usually expecting like. RV fridge compressors, loadwise;
there may be a jumper you can install, contact the manufacturer- although rapid oxidation and telecommunications cabinets do not agree with each other, had you considered a more conservative absorbed glass mat battery chemistry?
Voltage leads placed where, precisely? banana jacks on the front? ckt breaker output? input? Battery terminals?
BMS's are dark sorcery and well beyond the scope of my meager abilities, others likely to be more helpful
joecrowley
Thu Feb 19, 2026 2:01 pm
Julian wrote:LiFePo's are not like other batteries - V can't sag much, otherwise burny burny achy breaky, they have whole circuit boards in them to keep the lithium from the rapid oxidation it so desperately craves- switch may not actually be drawing enough to register on the battery's controller and it's going to sleep? I know they're usually expecting like. RV fridge compressors, loadwise;
Hi Julian,
Well I can pretty much confirm that the BMS is not cutting voltage to the circuit when the power-cycle happens with the WS-12-250 DC. I still read steady voltage at the terminals on the switch. I also have powered on other devices that take even less load, such as a Mikrotik HEX S (E60iUGS). and the device remains powered on indefinitely.
I have been using AGM deep cycle batteries for years and am trying to move to Lithium in order to increase capacity and battery life time. The idea is to deploy this setup into a solar powered remote WISP enclosure. So absorbed glass matt chemistry is a step backwards.
any other thoughts? Thanks for your input.
Julian
Wed Feb 25, 2026 1:06 pm
Handhelds in general, and indeed human eyes, aren't really precise enough to give you more than a macro order of magnitude view of the power in circuit, they don't provide a clear picture of what's actually going on at the timescales that matter. I did have a fluke scopemeter somewhere that I'd possibly try the "ripple" preset out for this; I'd let you borrow it if I remembered where it was, but I can't lend out my actual oscilloscope (apologies, I've bought cars for less).
If I must delve into the dark sorcery that is your specific BMS, I can - would you mind sharing vendor and part #?
lithium in a cabinet scares me, but it's your box - I'm just here to help work the problem and will keep my anxiety to myself in future.
there can be internal/other reasons for this, too--
do these two units specifically behave on other DC supplies?
Any change in behavior if you depopulate SFPs, or do those exist in this application?
thanks,
Julian
dgibler
Sun Jun 14, 2026 8:41 pm
I have a similar issue on a WS3. WS3 will not boot on 48v https://forum.netonix.com/viewtopic.php?f=17&t=8443by
dgibler » Fri Jun 12, 2026 2:09 pm
Have you found out any more information?
Users browsing this forum: Google [Bot] and 160 guests
