Hi all,
I have a WS-8-150-DC that after a IP change and reboot wont boot!!
I have run the Switch repair tool via console but this didn't solve the problem.
On boot it get to this stage and then no further, the ethernet ports work until this point! Also the Eth6 port is active at this point but you can not access the switch or do anything..
Is there anything I can do?
ç
Jan 1 00:00:05 kernel: SLUB: Genslabs=6, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Jan 1 00:00:05 kernel: Calibrating delay loop... 277.70 BogoMIPS (lpj=1388544)
Jan 1 00:00:05 kernel: Mount-cache hash table entries: 512
Jan 1 00:00:05 kernel: net_namespace: 640 bytes
Jan 1 00:00:05 kernel: NET: Registered protocol family 16
Jan 1 00:00:05 kernel: NET: Registered protocol family 2
Jan 1 00:00:05 kernel: Switched to high resolution mode on CPU 0
Jan 1 00:00:05 kernel: IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 00:00:05 kernel: TCP established hash table entries: 4096 (order: 3, 32768 bytes)
Jan 1 00:00:05 kernel: TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 00:00:05 kernel: TCP: Hash tables configured (established 4096 bind 4096)
Jan 1 00:00:05 kernel: TCP reno registered
Jan 1 00:00:05 kernel: squashfs: version 3.0 (2006/03/15) Phillip Lougher
Jan 1 00:00:05 kernel: Registering mini_fo version $Id$
Jan 1 00:00:05 kernel: JFFS2 version 2.2. (NAND) (SUMMARY) © 2001-2006 Red Hat, Inc.
Jan 1 00:00:05 kernel: msgmni has been set to 246
Jan 1 00:00:05 kernel: io scheduler noop registered
Jan 1 00:00:05 kernel: io scheduler deadline registered (default)
Jan 1 00:00:05 kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
vtss_core: module license '(c) Vitesse Semiconductor Inc.' taints kernel.
i2c /dev entries driver
^C
Please press Enter to activate this console.
BusyBox v1.19.4 (2022-02-15 14:35:04 EST) built-in shell (ash)
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
^C
@OpenWrt:/#
WS-8-150-DC Wont boot
- axarfusion
Re: WS-8-150-DC Wont boot
I would try breaking at redboot> prompt (power on, issue control-c via RS232 FAST, like nearly simultaneously, you may miss the first few times, success is marked by redboot> and a cursor) - and issuing, without quotes, backspacing, or special characters, 'fis load -d linux_recovery' <enter> 'go' <enter> first. if this was what you meant by the switch repair tool, forgive my misunderstanding, and read on, sir -
What kind of cables do you have around? I've used a Bus Pirate 3 and flashrom to get around this one, you'll need me to make an image for your specific switch, which is not too big of a deal, but you've got to be comfortable opening it up, the header you need is internal. If so, I can add a procedure to this thread
Sending it over for a reflash is going to be your less hands-on option but obviously carries expenses past a $20 USB adapter and some attention to detail on your end- please, how best may I assist?
Users browsing this forum: No registered users and 343 guests
