WS-26-500-DC V1.5.16
spajjie
Mon Mar 10, 2025 6:19 am
I recently made a mistake of selecting Port 6 Trunk Port / Allowed VLANS checkbox. And now I cannot deselect it. What gives? Dodgy firmware?
Here is my VLAN list:
NET02# show vlans
ID Enable Description 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26
1 true Vlan1 U U U U U T E E U U U U U U U U U U U U U U E E U U
2 true Vlan2 T E T E E U E U E E E E E E E E E E E E E E U E T T
3 true Vlan3 E E T E E T U E E E E E E E E E E E E E E E E U T T
Also, I'm trying to understand how I can tag traffic originating from Port 19 (A windows server) with a new VLAN4 tag. VLAN4 packets need to exit via Port 6 up to a Ubiquiti switch.
Any help would be greatly appreciated.
Chris
Re: WS-26-500-DC V1.5.16
Mon Mar 10, 2025 10:01 am
First upgrade to v1.5.25
We only support the current/latest version, sorry.
Cdev
Has thanked: 9 times
Thu Mar 13, 2025 3:52 pm
when you go to untick the trunk vlan, are you editing the vlan range?
if it says '1-4095', remove the text from the field and hit okay, this should remove the trunk
spajjie
Fri Mar 14, 2025 9:27 am
sirhc wrote:First upgrade to v1.5.25
Is it advisable to go from 16 to 25 directly? Or is it safer to go through each release incrementally?
Julian
Been thanked: 9 times
Fri Mar 14, 2025 2:52 pm
I do 1.5.16-1.5.25 every day, lately, multiple times - Think your password reverts to default if changed? I always default first, have read reports, have not experienced personally.
DO NOT SKIP THIS NOTE: May also need to reseat your SFP or reboot after upgrade, I'm not sure why but certain SFPs don't wake back up? none of my FS.com rj adapters do it, but my Molex one does - Then again that one causes most things I plug it into to reboot on insertion, ymmv. But if you're doing it in production you need to know this
spajjie
Mon Mar 17, 2025 5:22 am
Thanks - just wondering if there is official documentation regarding VLANs on the Netonix range?
spajjie
Thu Mar 20, 2025 1:43 am
Hi, this is now upgraded to the latest version.
Here is our current VLAN tag table;
NET02# show vlans
1 true Control U U U U U T E U U U U U U U U U U U U E U U E E U U
2 true CORP T E T E E U E E E E E E E E E E E E E E E E U E T T
3 true CCTV E E T E E T U E E E E E E E E E E E E E E E E U T T
4 true PLC E E E E E T E E E E E E E E E E E E T U E E E E E E
VLAN 1 IPv4 Address: 192.168.1.51/255.255.255.0
VLAN 4 IPv4 Address: 192.168.1.87/255.255.255.0
NET02#
I want to get port 19 traffic to be able to send traffic upstream VLAN 4 via Port 6 to a Mikrotik waiting on VLAN 4 on Port 1.
Struggling with this device as I don't have a clear picture of how the traffic leaves the Netonix.
Simply: Why can't I send ping traffic over to the other side leaving via port 19, get tagged on 4, go up the trunk, then hit the Mikrotik only for it then untagged VLAN 4 traffic and place it on Eth 1 for it to respond to the ICMP request.
Users browsing this forum: No registered users and 92 guests
