Latest WS Stable Release: v1.5.23
***NOTE:
WILL RESET PASSWORD BACK TO DEFAULT PASSWORD "admin" WHEN UPGRADING SO YOU MUST RESET PASSWORD AFTER UPGRADE IF UPGRADING FROM BELOW 1.5.17
(including 1.5.17rc2)
Personally we feel this is the most stable and best firmware since v1.4.8. (THIS IS CHRIS, I THINK BEST EVER)
We have been testing this intensely for weeks.
***NOTE:
Some people use a smart power strip that will reboot a switch if pings stop.
This upgrade process can take longer than normal due to a lot of house
keeping from the vast changes in code. So if the unit is power cycled
during the upgrade it is bricked. Make sure to disable this or increase
time missing pings till reboot 10 minutes or more.
***NOTE (Smart DC Switches):
On the original 1.5.17 release, it was noted that certain DC models could get bricked.
It appears that during firmware ugprade, sometimes it will also upgrade the firmware on the power supply which was being blocked by a failed semaphore init. This could easily have been corruption on download or possibly upload. But we have also added additional checks in an attempt to circumvent this issue should it appear again.
HOWEVER,
especially for smart DC models. We suggest you upgrade one that is easy for you to access in case anything goes wrong FIRST. Then continue
rollout if all goes well.
FIXED/CHANGED
- lighttpd upgraded - 1.5.17rc1
- Openssl upgraded - 1.5.17rc2
- Upgrade failure on very old WS models -1.5.17rc2
- Patched security holes to prevent hacking, however you should always use the Access Control List as good practice. - 1.5.17
- Removed PHP replaced with compiled binaries (approximately 60,000 lines of code needed re-written) - 1.5.17
- Greatly improved SFP compatibility and Stability where you saw SFPs not come up after upgrades and reboots - 1.5.17
- Fixed potential multi reboots due to certian configurations during warm boots and firmware upgrades - 1.5.17
- Fixed NTP - 1.5.17
- Fixed SNMP memory leak - 1.5.17
- Upgraded password hash (WILL RESET PASSWORD BACK TO DEFAULT "admin"
WHEN UPGRADING REQUIRES PASSWORD RESET AFTER UPGRADE IF PREVIOUS VERSION
IS BELOW 1.5.17) - 1.5.17
- Upgraded session hash algorithm - 1.5.17
- Fixed MAC table lookup and updated to latest vendor list - 1.5.17
- NTP scripts fixed - 1.5.18
- fixed special characters (aka !#@, etc) during login - 1.5.18
- checks added during boot for smart i2c supply BE CAUTIOUS WHEN UPGRADING SMART DC SWITCH'S (WS-12-250-DC, WS-8-150-DC, etc) - 1.5.18
- ssh login now only accepts correct password - 1.5.19
- VLAN's and other variable length conf items no longer limited - 1.5.20
- If greater than 30 VLAN they will now be applied correctly - 1.5.21
- Radius login fixed - NOTE, POSSIBLE SECURITY HOLE FOUND IN ORIGINAL IMPLEMENATION (pre-1.5.17) - 1.5.21
- Autobackup filenames fixed - 1.5.21
- DHCP fixed - 1.5.22
- web conf check command fixed - 1.5.22
- SMTP From Address now used when populated, otherwise defaults to switch ip - 1.5.22
- Ingress/Egress Throughput samples now account for delays lasting longer than a second, preventing weird spikes on port status - 1.5.22
- Memory corruption spikes on smart DC switch Input Voltage graphs looks fixed after 24 hour testing, please report if more are seen - 1.5.22
- NTP enable/disable will now trigger update immediately - 1.5.23
- SSH Key length extended to 1000 characters to accommodate common algorithms - 1.5.23
- WebUI Sessions can now expire, but will remain open with the webui - 1.5.23
- Multicast Configuration bug fix, this is potentially responsible for spontaneous issue's that have been reported with SFP's, PPPoE, OSPF, etc but due to testing complexity we cannot be certain, please let us know if you see any improvements if you have been experiencing these problems - 1.5.23
ENHANCEMENTS
- UI works faster as it is binary verses PHP - 1.5.17
KNOWN ISSUES
Released 12/14/2024
v1.5.23 Bug Reports and Comments
- oeyre
- Been thanked: 13 times
Re: v1.5.23 Bug Reports and Comments
Can confirm this did not brick my testing unit
Will try my affected unit later and advise.
Come on guys, Stephen basically worked 7 days a week on this for over 3 months. I did a "little" too but I'm an owner so that don't count.
This hacker shit cost us at least $125K when you factor in everyone's pay over this time that touched this project. But in the end, we ended up with a MUCH BETTER MORE STABLE FIRMWARE.
We had to get this stable before finishing the NEW WS3-E switches which were supposed to be out in October/November now looking at end of February "if" he works just as hard for 2+ more months.
If you have a valid issue report it but if you have good results, PLEASE take 5 minutes and leave some feedback. Not only does it allow us to move forward but I am sure Stephen would feel appreciated.
For those who have been actively testing and working with us I would like to say THANK YOU VERY MUCH you are greatly appreciated.
- IntL-Daniel
- Experienced Member
- Has thanked: 7 times
- Been thanked: 10 times
New reported bug in SMTP viewtopic.php?f=17&t=8132&start=20#p39154 probably remain in 1.5.23 (not mentioned in changelog)?
IntL-Daniel wrote:New reported bug in SMTP viewtopic.php?f=17&t=8132&start=20#p39154 probably remain in 1.5.23 (not mentioned in changelog)?
So this is not a bug report it is an untested observation.
Try it.
- IntL-Daniel
Still the same in 1.5.23, no way to send an email if "From Address" field is filled in.
- oeyre
Upgraded my problem unit to 1.5.23, BFD/OSPF still stuck in Init. No change when I disabled and enabled multicast on the ports.
oeyre wrote:Upgraded my problem unit to 1.5.23, BFD/OSPF still stuck in Init. No change when I disabled and enabled multicast on the ports.
Seems strange as some have no issue with PPPoE and a few do. Just told stephen we will have to arrange a time when we all 4 have access to said switch. We can use 3 way call but prefer SKYPE (I am old school) and RADMIN which you will have to install on your workstation.
If this is HEAVY production switch we will do best to work on in off hours like 2-3 AM. A light loaded switch that could be done at easier hours would be better.
If this involves SFP modules I would like you to acquire 2 "Cisco Genuine" SFP modules to be able to swap out, I know they are $$$ but will provide a base line we need.
IntL-Daniel wrote:Still the same in 1.5.23, no way to send an email if "From Address" field is filled in.
Again, some people claim it works others have issues.
So Stephen tested with mail server he install on one of his linux machines.
I asked him to test with commercial platforms like GMAIL, YAHOO...
If it works I asked him to make post on proper setup if broken then fix it.
But I told him to take rest of weekend off and do something with his family for a change. He really has been at this almost 7 days a weeks for 3 months.
- Been thanked: 208 times
Hello IntL-Daniel,
When filling in the From Address field, if not doing so already, please try using just the domain in the From Address input.
More details here: viewtopic.php?f=17&t=8132&start=90#p39224
Users browsing this forum: No registered users and 165 guests
