Switch stopped logging WS-8-150-DC
jim lemke
Thu Nov 14, 2024 4:38 pm
Jan 1 00:00:10 sysinit: killall: udhcpc: no process killed
Jan 1 00:00:13 kernel: vtss_core: module license '(c) Vitesse Semiconductor Inc.' taints kernel.
Jan 1 00:00:13 kernel: switch: 'Luton26' board detected
Jan 1 00:00:14 kernel: vtss_port: Loaded port module on board Luton26, type 5
Jan 1 00:00:15 kernel: nf_conntrack version 0.5.0 (2048 buckets, 8192 max)
Jan 1 00:00:15 system: Setting MAC address from flash configuration: EC:13:B2:E2:BE:90
Jan 1 00:00:15 kernel: i2c /dev entries driver
Jan 1 00:00:15 kernel: i2c_vcoreiii i2c_vcoreiii: i2c bus driver on IRQ 19
Jan 1 00:00:16 sysinit: Loading defaults
Jan 1 00:00:17 sysinit: Loading synflood protection
Jan 1 00:00:17 sysinit: Adding custom chains
Jan 1 00:00:17 sysinit: Loading zones
Jan 1 00:00:18 sysinit: Loading forwarding
Jan 1 00:00:18 sysinit: Loading redirects
Jan 1 00:00:18 sysinit: Loading rules
Jan 1 00:00:18 sysinit: sh: bad number
Jan 1 00:00:18 sysinit: Loading includes
Jan 1 00:00:18 admin: adding lan (eth0) to firewall zone lan
Jan 1 00:00:19 dropbear[819]: Running in background
Jan 1 00:00:20 netonix: 1.5.16 on WS-8-150-DC
Jan 1 00:00:23 UI: web config OK
Jan 1 00:00:26 kernel: eth0: no IPv6 routers present
Dec 31 18:00:27 syslogd exiting
Dec 31 18:00:28 syslogd started: BusyBox v1.19.4
Dec 31 18:00:28 syslogd exiting
Dec 31 18:00:29 syslogd started: BusyBox v1.19.4
Dec 31 18:00:30 admin: removing lan (eth0) from firewall zone lan
Dec 31 18:00:34 admin: adding lan (eth0) to firewall zone lan
Dec 31 18:00:35 admin: removing lan (eth0) from firewall zone lan
Dec 31 18:00:38 admin: adding lan (eth0) to firewall zone lan
Dec 31 18:00:45 admin: adding lan (eth0) to firewall zone lan
Dec 31 18:00:46 sysinit: Terminated
Dec 31 18:00:46 dropbear[1714]: Failed listening on '22': Error listening: Address already in use
Dec 31 18:00:46 dropbear[1714]: Early exit: No listening ports available.
Dec 31 18:00:46 dropbear[1721]: Running in background
Dec 31 18:00:47 sysinit: killall: telnetd: no process killed
Dec 31 18:00:47 sysinit: killall: ntpclient: no process killed
Dec 31 18:00:47 system: starting ntpclient
Dec 31 18:00:49 sysinit: 1969-12-31 18:00:48: (network.c.272) warning: please use server.use-ipv6 only for hostnames, not without server.bind / empty address; your config will break if the kernel default for IPV6_V6ONLY changes
Re: Switch stopped logging WS-8-150-DC
Fri Nov 15, 2024 3:33 pm
Upgrade to v1.5.17 and if problem exist then let us know.
Users browsing this forum: No registered users and 83 guests
