v1.5.15rc2 Bug Reports and Comments
Been thanked: 1362 times
Fri Nov 03, 2023 11:32 am
Latest WS Release Candidate: v1.5.15rc2
Click HERE to download firmware v1.5.15rc2 - Released 11/3/2023
FIXED/CHANGED
- Fixed SNMP init error (causing memory leaks) - rc1
- Fixed kernel page-cache failure - rc1
- Fixed watchdog memory leak - rc1
- Fixed leak in net-snmp causing "No MemShared" error in logs - rc2
ENHANCEMENTS
KNOWN ISSUES
Released 11/3/2023
Re: v1.5.15rc2 Bug Reports and Comments
Sun Nov 05, 2023 6:04 pm
We are looking at the issue some people report about bouncing SFP modules on config changes.
We are only seeing it when you add or remove a VLAN.
Now keep in mind I disable STP / RSTP on my SFP ports because they are usually in a 2 port VLAN for my back hauls with the SFP to router and copper port to AF24. Those ports can never see a loop as they are fixed on both ends and I never wanted an OSPF convergence to occur from an STP / RSTP (false) event.
Stephen is looking into if this can be avoided. It occurs due to SFP re-initializing and as I said if STP / RSTP in on for that port then it has to go through that process as well prolonging the even and making it more noticeable.
NO COMMENTS ON RC2 YET????
RTGLW
Has thanked: 29 times
Been thanked: 15 times
Sun Nov 05, 2023 11:09 pm
We deployed RC2 on one of our switches this morning (NZT) to test. Will report back tomorrow to confirm that we no longer see memory loss occurring after a longer uptime, but preliminary results after <8 hours is looking promising.
summit-nathan
Has thanked: 3 times
Mon Nov 06, 2023 1:28 am
I've just upgraded one on a test site now. Public holiday tomorrow so will report back on memory usage after that.
Turning off STP does make the SFP issue much less impacting but it is still there. We've tested and think this SFP issue might have appeared sometime after firmware 1.5.5.
We've tested a WS-8-150-DC with firmware versions 1.5.12, 1.5.14 and 1.5.15rc1 and observed the SFP issue on all of them.
We could replicate the SFP issue on the command line as follows:
Code: Select all
show log
config t
 vlan 10
  port 4 t
  exit
 exit
show log
Mon Nov 06, 2023 8:26 am
Now you only have to turn STP / RSTP OFF on SFP ports (Captain obvious here).
Not sure how or if we can get around this yet, but Stephen is looking at.
RTGLW
Mon Nov 06, 2023 3:30 pm
RTGLW wrote:We deployed RC2 on one of our switches this morning (NZT) to test. Will report back tomorrow to confirm that we no longer see memory loss occurring after a longer uptime, but preliminary results after <8 hours is looking promising.
After 24 hours we've seen no size increase in our test switch's snmpd.log file, the "No MemShared" error is not showing in logs, and overall available memory has stayed the same. I'll roll this out to a few of our production hosts as well to increase sample size, but looking good so far. Cheers guys.
Been thanked: 207 times
Tue Nov 07, 2023 12:53 pm
Hello everyone, v.1.5.15rc3 is out. This thread will now be closed.
Please go to the v1.5.15rc3 Bug Reports and Comments thread to download the latest release candidate firmware and report bugs/comments.
