Working Switch; DOA Fan
dk4063
Mon Jun 15, 2015 6:48 pm
I have two WS-24-400A switches both of which work phenomenally, however, I noticed that one would oscillate the fans on and off every minute or so. I checked the status interface and noticed one fan reporting 0 RPM. After visually confirming the identity and failure of the fan, I'm not certain what to do for RMA's. It seems the only way I would be able to order a new fan is to purchase 30 of them through Digikey. I was hoping for more guidance from the forum.
I'm very pleased with the product; we are currently utilizing them as the core backbone of a mobile communication platform with a VMWare cluster as it's heart. I've pushed as high as 2.4 gbps throughput on the devices over a 4 channels LACP interface group. I can also confirm the operation of SFP+ interface interconnect cables made by Cisco (SFP-H10GB-CU5M). They obviously do not operate at 10 GB, however, they provide stable connection at 1 GB. Also, Cisco (CAB-SFP-50CM) work as well, however, it seems that the interfaces on Cisco SFP and Netonix SFP are not compatible, ie. Netonix interconnecting functions with the cable and cisco interconnecting functions with the cables but connecting cisco to Netonix will not work.
David
Re: Working Switch; DOA Fan
Mon Jun 15, 2015 7:01 pm
I can sell you replacement fans but it is hard to believe they are failing this soon.
We will sell them for $9.95 each with connector installed.
I will put them on the web store tomorrow.
What firmware are you using?
Also PM me your cell as I would like to have you check a couple things.
Users browsing this forum: No registered users and 25 guests
