Hi... the JFFS partition fills up to 100% on my switches, this has happened to more than one switch... after saving configuration changes over time.
I can't find any files in partition causing the problem or any that you can delete to recover some space??
The only way to fix this disk full error problem is to reboot switch disrupting services. Anyone (Netonix) know a fix without rebooting? or removing some temporary files somewhere?
thanks
Matt
JFFS partition goes to 100% over time.. with no evidence.
- matthew
- fictitiousexistence
Re: JFFS partition goes to 100% over time.. with no evidence
There's another post here https://forums.netonix.com/viewtopic.ph ... 32c#p37771
I just had the same issue and couldn't save config.
For me it (seems to have been) because I tried to scp a newer firmware to /tmp as suggested in another thread, it failed with not enough space.
I upgraded from the gui but found the partial failed firmware file at /root using up 2.9Mb. Deleted it and am fine so far.
