I have a WS-8-150-DC switch which is not saving configurations changes. The current firmware is a1.5.8.
Attempted changes show in the log:
Jul 18 18:02:11 UI: IPv4_Secondary_DNS: changed from '8.8.8.8' to '8.8.4.4'
When the changes are saved the following error shows up:
Error saving configuration!
Any idea what may be causing this or how to fix it?
Is a firmware update safe or recommended in this condition?
Additional information. A command line "show logs" brings up the ferrors listed below which shows "no free space". A "df" shows nearly identical output as a working unit.
Jul 24 13:16:18 kernel: Error garbage collecting node at 0043f2a4!
Jul 24 13:16:18 kernel: Argh. No free space left for GC. nr_erasing_blocks is 0. nr_free_blocks is 0. (erasableempty: yes, erasingempty: yes, erasependingempty: yes)
Jul 24 13:16:18 kernel: mini_fo_open: invalid file state detected.
Jul 24 13:17:22 kernel: Argh. No free space left for GC. nr_erasing_blocks is 0. nr_free_blocks is 0. (erasableempty: yes, erasingempty: yes, erasependingempty: yes)
Jul 24 13:17:22 kernel: Error garbage collecting node at 0043f2a4!
Jul 24 13:17:22 kernel: mini_fo: create_sto_file: ERROR creating sto file.
Jul 24 13:17:22 UI: Configuration changed by admin (::ffff:24.69.183.0)
Jul 24 13:17:22 UI: Port 1 STP: changed from 'Enabled' to 'Disabled'
Jul 24 13:17:22 UI: Port 2 STP: changed from 'Enabled' to 'Disabled'
Jul 24 13:17:22 UI: Port 3 STP: changed from 'Enabled' to 'Disabled'
Jul 24 13:17:22 UI: Port 4 STP: changed from 'Enabled' to 'Disabled'
Jul 24 13:17:22 UI: Port 5 STP: changed from 'Enabled' to 'Disabled'
Jul 24 13:17:22 UI: Port 7 STP: changed from 'Enabled' to 'Disabled'
Jul 24 13:17:22 UI: Port 8 STP: changed from 'Enabled' to 'Disabled'
Jul 24 13:17:23 kernel: Argh. No free space left for GC. nr_erasing_blocks is 0. nr_free_blocks is 0. (erasableempty: yes, erasingempty: yes, erasependingempty: yes)
Jul 24 13:17:23 kernel: Error garbage collecting node at 0043f2a4!
Jul 24 13:17:23 kernel: mini_fo: create_sto_file: ERROR creating sto file.
WS-8-150-DC - Error saving configuration!
- kevin
1 post
