We've recently been having more and more random switch reboots which results in all powered devices being power cycled as well. We do not have STP enabled and I don't believe it's STP related. Running 1.5.14 on all the affected switches.
Does anyone have any suggestions what might be causing this?
I am considering downgrading to 1.5.5 if we can't find the culprit.
Random poe off reboots
LRL - Experienced Member
- Has thanked: 19 times
- Been thanked: 49 times
-LRL
Re: Random poe off reboots
Multiple memory leaks have been reported in v1.5.14 Bug Reports and Comments which does force a reboot of the netonix switch.
Are you running SNMP to monitor switch stats?
Indeed we are.
-LRL
