Apologies if this post is a repeat, i searched the forum but could not find an answer. I am currently trying to upgrade to v 1.5.14 on a variety of models but want to know if I have to take steps between versions to keep the stability of the hardware. The oldest version I have found in my estate is 1.5.2.
Is there a specified recomended version path to follow or can i just go straight in with 1.5.14?
many thanks
wisp switch upgrade path
- rossgofibre
mayheart - Experienced Member
- Has thanked: 48 times
- Been thanked: 59 times
Re: wisp switch upgrade path
I've never seen an issue with upgrading from 1.4 or any 1.5 to 1.5.14. We have hundrews of switches out in the field.
- rossgofibre
Thank you I thought it would be ok but just thought i would check
