ws-8-150-dc website entry stuffed up
jackkirk
Thu Feb 23, 2023 4:30 am
If you go to:
https://netonix.com/wisp-switch/ws-8-150-dc.html
it indicates item is in stock and a default [Qty] of 1 is showing.
If you tap [Add to Cart] you get a message "The requested qty is not available"
If you tap [Qty] it shows 100 and all attempts to change it cause it to revert to 100.
What gives?
Re: ws-8-150-dc website entry stuffed up
Thu Feb 23, 2023 10:24 am
Thu Feb 23, 2023 10:55 am
sirhc wrote:https://forum.netonix.com/viewtopic.php?f=5&t=7556&p=37010&hilit=out+of+stock#p37010
Chris, that does not explain why QTY would show 100 and not be able to change it.
