WS-12-250-DC can work whitout fan?
opalmag
Thu Dec 01, 2022 9:56 am
Hi to all.
We have a WS-12-250-DC who got damage the POE power modules (if conect devices does''t power it) after a lligthning strike, but as switch is fully functional, so I take it as switch to my workstation, but from time to time the SW make a fan test for a few minutes and make a lot of noise.
With the premise that the SW is not making any POE functions and is an office enviroment, is posible to function without the fan?
Been thanked: 158 times
Re: WS-12-250-DC can work whitout fan?
Thu Dec 01, 2022 2:41 pm
yes, it should be okay without fan & no POE devices...assuming air-conditioned office.
opalmag
Thu Dec 01, 2022 6:23 pm
Wolud be the espected temp in wich the sw reach a critical level that can afect the CPU?
Fri Dec 02, 2022 9:43 am
as long as CPU temp doesn't go above 110 degree you are okay
