Network Bonding ?
wtm
Has thanked: 41 times
Been thanked: 36 times
Network Bonding ?
Fri Aug 19, 2022 12:42 pm
Can you please advise on what LACP modes (0-6) that the Netonix switch corolates to on the drop down box entries under the LACP tab?
(RR, 802.3ad, XOR, etc) (Static ?)
We are having problems with trying to bond more than 2 devices together, and need to figure out what modes are being used, and what we should be using?
mayheart
Has thanked: 48 times
Been thanked: 60 times
Re: Network Bonding ?
Fri Aug 19, 2022 2:18 pm
It's 802.3ad.
I have it working fine with a Cisco ASR920 and a GPON shelf for management.
What I have enabled:
Cisco port 1: Key #1, LACP-P, Slow
Cisco port 2: Key #1, LACP-P, Slow
GPON port 1: Key #2, LACP-P, Slow
GPON port 2: Key #2, LACP-P, Slow
Spanning tree enabled on the ports facing the two seperate devices in RTSP mode.
wtm
Fri Aug 19, 2022 3:47 pm
I can get it to do bonding to 2 devices, problem is that we have 3 devices that we need to do. When you connect up the 3rd device the bond fails !
