Turn off https?
alohabro
Been thanked: 3 times
Turn off https?
Mon May 02, 2022 2:14 pm
I can not access certain netonix with chrome because of their SSL settings. Its no big deal because I can usually just turn off SSL on all our internal network devices.
But when I try to disable https in the netonix it throws this error: If you disable HTTPS you will not be able to access this web GUI
So is there now no way to disable https and access the web gui?
KBrownConsulting
Has thanked: 15 times
Been thanked: 18 times
Re: Turn off https?
Mon May 02, 2022 4:56 pm
Upgrade to the latest firmware which fixes the SSL issue.
