Netonix WISP SSL/TLS Issue
seancsmith89
Fri Feb 11, 2022 6:12 am
Hi all,
I am having SSL issues reaching all Netonix devices on our networks via the GUI. We have multiple of these devices of several networks and all, up until last week, I was able to connect to via the GUI. I can get on them via SSH without issue but any time I tried to get the GUI I get the image shown at the bottom. I am wondering, first of all, why has my cert., that I must have previously had, dissapeared? And where can I get a new one?
From other PCs/Laptops in the office I can get onto every devices GUI but just not my own laptop for some reason.
I checked the logs on the radio (Via SSH) to see if it showed anything here but nothing.
I have saw that a lot of people have recommended an init.d restart but since this is the case for multiple devices on multiple networks, and the fact that my colleagues can reach these radios, then I am not sure if this would be the solution or not.
Any help please guys 'n' gals? Pirate4
Mod edit: removed inline graphic. Please use attachment instead.
gnorton
Re: Netonix WISP SSL/TLS Issue
Fri Feb 11, 2022 10:44 am
Your version of chrome must have updated, and the latest versions of both Chrome and IE no longer support the older ssl protocol used by Netonix. This will require a firmware upgrade from Netonix to fix. In the mean time you should still be able to access it with the current version of Firefox, you will just have to accept the security warnings.
seancsmith89
Tue Feb 15, 2022 8:11 am
Hey Gnorton!
Thanks for the reply :)
Unfortunately a FW upgrade to the most recent (Unless I am wrong) 1.5.9 did not sort the issue out and we can still only access with IE or Firefox; Chrome is preferred for us though. (Looooong story!)
And I can ssh in though, which will do for the time being.
Accel Wireless
Fri Feb 18, 2022 12:55 am
Same thing here, very annoying. Is netonix going to fix the issue?
Fri Feb 18, 2022 9:04 am
Fixed in 1.5.10
yubavillage
Thu Mar 24, 2022 8:03 pm
I can no longer access the GUI in order to upgrade to the latest firmware. Where is the documentation on how to upgrade over SSH?
Fri Mar 25, 2022 10:40 am
yubavillage wrote:I can no longer access the GUI in order to upgrade to the latest firmware. Where is the documentation on how to upgrade over SSH?
The easiest way is to use an older browser such as IE.
Else read this thread: viewtopic.php?f=6&t=1377#p10162
