Netonix WebUI no longer works in chrome V98
RubenW
Thu Feb 10, 2022 12:58 pm
Since this week the Netonix WebUI no longer works in google Chrome.
Since Chrome version 98, TLS 1.0 and 1.1 are no longer supported and no longer bypassable.
Information from Google Chrome.
https://chromestatus.com/feature/5759116003770368
generally you'll get following error code
This site can’t provide a secure connection
[HOSTNAME] uses an unsupported protocol.
ERR_SSL_VERSION_OR_CIPHER_MISMATCH
I hope there will be an update soon to replace TLS1.0 with a more recent version !!
It starts now with chrome, but all major webbrowsers are following soon.
dcshobby
Been thanked: 10 times
Re: Netonix WebUI no longer works in chrome V98
Thu Feb 10, 2022 2:19 pm
I can no longer get into any of our Netonix since updating Chrome.
Is there another browser that will work? Edge also gives me the same error.
RubenW
Fri Feb 11, 2022 9:55 am
for the moment we are using IE, which still works
or there is still a bypass possible with firefox
Firefox workaround
- in the address bar go to about:config
- search for security.tls.version.min  change value from 3 to 1.
- restart
Users browsing this forum: No registered users and 78 guests
