After configuring SMTP on a WS-12-250-AC running firmware 1.5.8 I get the following message when I test the settings:
421 4.7.66 TLS 1.0 and 1.1 are not supported.
Please upgrade/update your client to support TLS 1.2.
ssmtp: Authorization failed (421 4.7.66 TLS 1.0 and 1.1 are not supported.
Please upgrade/update your client to support TLS 1.2. Visit https://aka.ms/smtp_auth_tls.
[BN8PR04CA0016.namprd04.prod.outlook.com])
Do any newer firmware revisions support TLS 1.2?
Thanks,
Doug
TLS 1.2 support
Re: TLS 1.2 support
Not yet sorry, working on it.
But why did you post this in the Pictures and stories threads instead of software?
Re: TLS 1.2 support
It may be helpful to move this to the correct thread.
By enabling less secure apps in gmail settings I was able to get it to work correctly.
Doug
Doug
Re: TLS 1.2 support
Yea I should have thought to tell you that, that is what my WISP does. Sorry, brain fart.
Re: TLS 1.2 support
How I feel about netonix not supporting TLS 1.2 in 2022....
- Attachments
- image.PNG (152.78 KiB) Viewed 25180 times
SupermanSC - Member
Re: TLS 1.2 support
No joke, there's a post from 2017 saying the same thing. That's 1/2 a decade ago.
jpaine619 - Member
- Has thanked: 26 times
- Been thanked: 19 times
Re: TLS 1.2 support
Eagle12 wrote:It may be helpful to move this to the correct thread.
Doug
Bummer. Can't enable that setting if 2FA is used
jpaine619 - Member
Re: TLS 1.2 support
Dave wrote:funny, TLS 1.2 support is on its way....
The Internet Engineering Task Force, the National Institute for Standards and Technology, and the Payment Card Industry Security Standards Council, mandate that operators of web servers ensure that they’re using the most up-to-date version of the protocol, TLS 1.2 before the end of 2020.
'nuff said.
