WS-8-150-AC
- Kelly Tolliver
WS-8-150-AC
I have aquired a new customer who owns a WS-8-15-AC. The client is a golf course and needs to send internet signal to some outer buildings. There is no documentation that I can find anywhere on how to configure or set up this switch. I cannot access it with my laptop. I do not see a way to "reset" it. Please help.
Omniflux - Experienced Member
- Has thanked: 5 times
- Been thanked: 32 times
Re: WS-8-150-AC
The documentation is here:
viewtopic.php?f=17&t=237
https://www.netonix.com/media/wysiwyg/ws-specsheet.pdf
If you want to access the switch without resetting its configuration, without a serial connection, and it is not at the default IP address, I would try connecting to the switch with Wireshark and rebooting the switch, then look for a Netonix MAC address. There should be a gratuitous ARP allowing you to see the IP address the switch is using. You'll still need the username and password, of course.
Users browsing this forum: No registered users and 187 guests
