Issues when port is negotiating oddly
mhoppes
Has thanked: 10 times
Been thanked: 125 times
Wed Dec 22, 2021 5:01 pm
Has anyone else seen this issue? Best as I can tell it may be caused by perhaps wind blowing something and causing the port to not fully hold negotiation.
Basically, the port will show "No Link" or start having issues passing data. You can reboot the radio and it doesn't really change anything. However, doing a power cycle on the port itself from the switch seems to cause the system to work again.
It's almost like something in the Netonix gets confused by errors on the port and can't recover without a full physical port restart.
Re: Issues when port is negotiating oddly
Mon Dec 27, 2021 10:56 pm
Only saw similar stuff with ESD issue.
mhoppes
Tue Dec 28, 2021 12:06 pm
So grounding issues in the switch again.... perfect....
