SFP port flaps on any config change
mayheart
Has thanked: 48 times
Been thanked: 60 times
Fri Nov 26, 2021 9:28 am
Hey there,
I've noticed this on a few switches running 1.5.9-RC1. This switch has spanning tree enabled, I've seen it happen on switches without spanning tree as well.
This is an example when I did a tag change and added a VLAN.
Code: Select all
Nov 25 16:04:39 UI: VLAN 991 PortSettings: changed from 'UEUUUUUEUUUUUUEEEEEEEEEEET' to 'UEUUUUUEUUUUEEEEEEEEEEEEET'
Nov 25 16:04:39 UI: VLANs: added 'OFFICE_MGMT'
Nov 25 16:04:49 STP: msti 0 set port 1 to discarding
Nov 25 16:04:49 STP: msti 0 set port 2 to discarding
Nov 25 16:04:49 STP: msti 0 set port 4 to discarding
Nov 25 16:04:49 STP: msti 0 set port 5 to discarding
Nov 25 16:04:49 STP: msti 0 set port 6 to discarding
Nov 25 16:04:49 STP: msti 0 set port 7 to discarding
Nov 25 16:04:49 STP: msti 0 set port 8 to discarding
Nov 25 16:04:49 STP: msti 0 set port 9 to discarding
Nov 25 16:04:49 STP: msti 0 set port 10 to discarding
Nov 25 16:04:49 STP: msti 0 set port 11 to discarding
Nov 25 16:04:49 STP: msti 0 set port 12 to discarding
Nov 25 16:04:49 STP: msti 0 set port 13 to discarding
Nov 25 16:04:49 STP: msti 0 set port 14 to discarding
Nov 25 16:04:50 STP: msti 0 set port 26 to discarding
Nov 25 16:04:52 STP: msti 0 set port 26 to learning
Nov 25 16:04:52 STP: msti 0 set port 26 to forwarding
Nov 25 16:04:52 STP: msti 0 set port 14 to learning
Nov 25 16:04:52 STP: msti 0 set port 14 to forwarding
Nov 25 16:04:52 STP: msti 0 set port 13 to learning
Nov 25 16:04:52 STP: msti 0 set port 13 to forwarding
Nov 25 16:04:52 STP: msti 0 set port 12 to learning
Nov 25 16:04:52 STP: msti 0 set port 12 to forwarding
Nov 25 16:04:52 STP: msti 0 set port 11 to learning
Nov 25 16:04:52 STP: msti 0 set port 11 to forwarding
Nov 25 16:04:52 STP: msti 0 set port 10 to learning
Nov 25 16:04:52 STP: msti 0 set port 10 to forwarding
Nov 25 16:04:52 STP: msti 0 set port 9 to learning
Nov 25 16:04:52 STP: msti 0 set port 9 to forwarding
Nov 25 16:04:52 STP: msti 0 set port 8 to learning
Nov 25 16:04:52 STP: msti 0 set port 8 to forwarding
Nov 25 16:04:52 STP: msti 0 set port 7 to learning
Nov 25 16:04:52 STP: msti 0 set port 7 to forwarding
Nov 25 16:04:52 STP: msti 0 set port 6 to learning
Nov 25 16:04:52 STP: msti 0 set port 6 to forwarding
Nov 25 16:04:52 STP: msti 0 set port 5 to learning
Nov 25 16:04:52 STP: msti 0 set port 5 to forwarding
Nov 25 16:04:52 STP: msti 0 set port 4 to learning
Nov 25 16:04:52 STP: msti 0 set port 4 to forwarding
Nov 25 16:04:52 STP: msti 0 set port 2 to learning
Nov 25 16:04:52 STP: msti 0 set port 2 to forwarding
Nov 25 16:04:52 STP: msti 0 set port 1 to learning
Nov 25 16:04:52 STP: msti 0 set port 1 to forwarding
Nov 25 16:04:56 Port: link state changed to 'down' on port 26
Nov 25 16:04:56 STP: msti 0 set port 26 to discarding
Nov 25 16:04:59 Port: link state changed to 'up' (1G) on port 26
Nov 25 16:04:59 STP: msti 0 set port 26 to discarding
Nov 25 16:05:02 STP: msti 0 set port 26 to learning
Nov 25 16:05:02 STP: msti 0 set port 26 to forwarding
mayheart
Re: SFP port flaps on any config change
Fri Nov 26, 2021 11:52 am
Another switch with spanning-tree disabled.
Code: Select all
Nov 26 09:47:59 UI: VLAN 32 ID: changed from '32' to '1000'
Nov 26 09:48:16 Port: link state changed to 'down' on port 26
Nov 26 09:48:19 Port: link state changed to 'up' (1G) on port 26
Discovery is also disabled on all the switches.
mayheart
Fri Nov 26, 2021 2:55 pm
on a 12 port unit running 1.5.9-RC1...
Code: Select all
Nov 26 12:16:03 UI: VLANs: added 'test'
Nov 26 12:16:09 Port: link state changed to 'down' on port 13
Nov 26 12:16:09 STP: msti 0 set port 13 to discarding
Nov 26 12:16:10 Port: link state changed to 'up' (1G) on port 13
Nov 26 12:16:10 STP: msti 0 set port 13 to discarding
Nov 26 12:16:12 STP: msti 0 set port 13 to learning
Nov 26 12:16:12 STP: msti 0 set port 13 to forwarding
mayheart
Fri Jan 07, 2022 12:11 pm
Any update on this?
I've had to downgrade to 1.5.5 to prevent this from happening.
mayheart
Tue Feb 15, 2022 12:47 pm
Bump.
Any traction on this?
Doing a vlan change and causing a temporarily network outage while the SFP bounces is pretty serve.
As my previous post, it looks something changed after 1.5.5.
IntL-Daniel
Has thanked: 7 times
Been thanked: 10 times
Tue Nov 15, 2022 7:58 am
And the same issue with any RSTP changes reported here. Any chance to fix at least this bug? Thanks!
mhoppes
Has thanked: 10 times
Been thanked: 125 times
Thu Jan 19, 2023 3:41 pm
We have stabilized on 1.5.5 as our stable release version for the time being -- that's how we've fixed this and many other issues.
mayheart
Sun Jan 22, 2023 5:25 pm
Yeah, that was around the time I started noticing issues as well. Something changed in 1.5.6 and beyond.
Garnet
Mon Jul 10, 2023 7:10 pm
mhoppes wrote:We have stabilized on 1.5.5 as our stable release version for the time being -- that's how we've fixed this and many other issues.
Can you please share what other issues you've noticed on recent versions that reverting to 1.5.5. fixed? A link to the forum post would work as well.
Cheers,
mayheart
Mon Jul 10, 2023 8:55 pm
Wow I reported this almost 2 years ago...
Will this ever get fixed?
