v1.2.2 FINAL bug reports and comments
Tue May 19, 2015 9:42 am
Please post comments and reports bugs with v1.2.2 in this thread
telcom
Re: v1.2.2 FINAL bug reports and comments
Tue May 19, 2015 10:48 am
So far so good - thanks for the update
anvilcom
Tue May 19, 2015 2:30 pm
Confirming the the ssmtp issue is fixed. Thanks for the quick work.
Wed May 20, 2015 10:17 am
Put it on a production switch and everything seem fine.
RebusCom
Has thanked: 14 times
Been thanked: 11 times
Sun May 24, 2015 1:03 am
It appears that if a port description is edited the associated ping watchdog description is not, nor can it be edited.
jportman
Sun May 24, 2015 7:17 pm
I upgraded a switch from 1.2.0rc8 and now cannot access the SNMP values.
Sun May 24, 2015 7:20 pm
The newer firmware now no longer supports snap v1 because of security concerns
jportman
Sun May 24, 2015 10:29 pm
Well, I changed dude to use version 2 and now the snmp is totally unstable. It shows correctly for one polling cycle, then zero for the next. The table of available devices keeps changing, etc. for my purposes, snmp is now officially broken.
Mon May 25, 2015 9:16 am
I'm down at shore right now but i am headed back later today.
Other people are using snmp ok just not v1?
We disabled v1 by request for security reasons.
I will talk to Eric about it later today
Eric Stern
Been thanked: 130 times
Mon May 25, 2015 1:10 pm
jportman wrote:Well, I changed dude to use version 2 and now the snmp is totally unstable. It shows correctly for one polling cycle, then zero for the next. The table of available devices keeps changing, etc. for my purposes, snmp is now officially broken.
What version of The Dude are you using. I'm testing with 3.6 on Windows 7 and it seems to work perfectly. Also testing with SnmpB, which also works fine.
