Netonix-Manager not working
macgyver
Wed Apr 28, 2021 8:50 pm
I have a new install of Ubuntu 20.04.2.0 LTS Desktop version. Installed nodejs and netonix-manager status shows active(running).
I cant open it in the browser https://localhost:3443 Nothing is listening on port 3443, Any ideas on what is missing?
Been thanked: 207 times
Re: Netonix-Manager not working
Thu Apr 29, 2021 2:53 am
Could be a couple things, what version of node is on your system?
macgyver
Thu Apr 29, 2021 9:50 am
Current version show 10.19.0 I have tried 8.16.0 and 14.16.1. All have the same issue
Fri Apr 30, 2021 5:50 pm
Try using version node 8.1.2 (it's easy to switch with nvm if you don't already use it)
Then completely uninstall the manager and try installing it again.
Let's see how that goes.
macgyver
Sun May 02, 2021 12:54 pm
Still the same issue.
oot@gene-NUC8i7BEH:/home/gene# ss -ltn
State Recv-Q Send-Q Local Address:Port Peer Address:Port Process
LISTEN 0 5 127.0.0.1:631 0.0.0.0:*
LISTEN 0 4096 127.0.0.53%lo:53 0.0.0.0:*
LISTEN 0 5 [::1]:631 [::]:*
LISTEN 0 511 *:80 *:*
root@gene-NUC8i7BEH:/home/gene# service netonix-manager status
● netonix-manager.service - LSB: Start daemon at boot time
Loaded: loaded (/etc/init.d/netonix-manager; generated)
Active: active (running) since Sun 2021-05-02 11:52:08 CDT; 30s ago
Docs: man:systemd-sysv-generator(8)
Process: 8314 ExecStart=/etc/init.d/netonix-manager start (code=exited, status=0/SUCCESS)
Tasks: 13 (limit: 38308)
Memory: 60.9M
CGroup: /system.slice/netonix-manager.service
├─8317 /usr/bin/nodejs bootloader.js
└─8960 nodejs app.js
May 02 11:52:08 gene-NUC8i7BEH systemd[1]: Starting LSB: Start daemon at boot time...
May 02 11:52:08 gene-NUC8i7BEH systemd[1]: Started LSB: Start daemon at boot time.
root@gene-NUC8i7BEH:/home/gene# node -v
v8.2.1
Gene Grant
Wed May 05, 2021 11:02 pm
I still have not been able to get this working, what am I missing?
Wed May 05, 2021 11:11 pm
Could you PM me the crashlog?
It should be located at
Code: Select all
/opt/netonix-manager/crash.log
It's possible this might be the issue, try this:
In the file /etc/ssl/openssl.cnf changing last line
Code: Select all
CipherString = DEFAULT@SECLEVEL=2
to
Code: Select all
CipherString = DEFAULT@SECLEVEL=1
macgyver
Thu May 06, 2021 5:57 pm
CipherString line does not exist in the file.
macgyver
Thu May 06, 2021 6:03 pm
I tried PM just stuck in outbox..
Here is the text from crash.log just keeps repeating
js-bson: Failed to load c++ bson extension, using pure JS version
_tls_common.js:135
c.context.setCert(cert);
Error: error:140AB18F:SSL routines:SSL_CTX_use_certificate:ee key too small
at Object.createSecureContext (_tls_common.js:135:17)
at Server (_tls_wrap.js:873:27)
at new Server (https.js:62:14)
at Object.createServer (https.js:85:10)
at Object.<anonymous> (/opt/netonix-manager/app.js:920:11)
at Module._compile (internal/modules/cjs/loader.js:778:30)
at Object.Module._extensions..js (internal/modules/cjs/loader.js:789:10)
at Module.load (internal/modules/cjs/loader.js:653:32)
at tryModuleLoad (internal/modules/cjs/loader.js:593:12)
at Function.Module._load (internal/modules/cjs/loader.js:585:3)
at Function.Module.runMain (internal/modules/cjs/loader.js:831:12)
at startup (internal/bootstrap/node.js:283:19)
at bootstrapNodeJSCore (internal/bootstrap/node.js:623:3)
_tls_common.js:135
_tls_common.js:135
Thu May 06, 2021 8:03 pm
OK i see the issue,
I'm going to have to do a bit more research to fix this issue but it is related to this version of Ubuntu.
I am able to run the manager on Ubuntu version 18.04.5 LTS if you can move back to that version, you should be OK.
Users browsing this forum: No registered users and 274 guests
