v1.5.8 Bug Reports and Comments
Been thanked: 210 times
Sat Apr 03, 2021 2:42 am
Click HERE to download firmware v1.5.8 - Released 4/3/2021
Click HERE to go to the Download Latest Firmware thread
v1.5.8 wrote:
IF A SWITCH ARRIVED WITH 1.5.5 PRELOADED PLEASE CHECK THIS THREAD
FIXED/CHANGED
- Enabling/Disabling ports on MSTP could result in loss of connectivity
- updating VLANs port types was not registered with MSTP
- Dropbear works again
ENHANCEMENTS
KNOWN ISSUES
- Some language templates need help - please private message Stephen Copeland to help
Released 4/3/2021
Re: v1.5.8 Bug Reports and Comments
Sat Apr 03, 2021 9:07 am
Thanks Stephen for the new firmware.
It would be nice to include the download link on "Bug Reports and Comments" thread since editing the first message of "Download latest Firmware" wont show this last as unread.
That would avoid us to go search for the other thread each time we see a new "Bug Reports and Comments" thread.
Sat Apr 03, 2021 12:33 pm
Makes sense to me.
makara
Sat Apr 03, 2021 5:28 pm
Hi, I attempted an upgrade from firmware 1.5.6 to 1.5.8 on a WS-12-250-DC and received the following message:
"This switch is using a newer temperature sensor because the older one has become obsolete, thus it is not compatible with the firmware that you attempted to upgrade too. Please only attempt to perform an upgrade with firmware 1.5.3 or greater"
Any suggestions?
Mon Apr 05, 2021 10:48 am
Hello makara,
Access the terminal for the switch via the web console, ssh, or serial console and run the following commands:
Code: Select all
cmd
rm /tmp/new_temp_sensor
Then attempt the upgrade again.
Let us know how that goes.
makara
Mon Apr 05, 2021 4:35 pm
Hi Stephen,
That worked thanks.
Does that message mean my switch has an old temp sensor, or a new temp sensor?
Tue Apr 06, 2021 1:48 pm
You're welcome - It means it's a new one.
mayheart
Has thanked: 48 times
Been thanked: 60 times
Tue Apr 06, 2021 7:54 pm
Hey Stephen,
The download links need to be updated to include https instead of http. Latest Chrome update is blocking http downloads from https sites.
Wed Apr 07, 2021 4:22 am
Thanks for the update mayheart, I've updated the download links.
coreinput
Been thanked: 14 times
Fri Apr 09, 2021 8:01 am
Upgraded from 1.5.6 running since February 2021 and everything went smooth (and no POE loss). Hats off to the team including beta testers for making this release happen. Thanks!
