v1.5.7 wrote:IF A SWITCH ARRIVED WITH 1.5.5 PRELOADED PLEASE CHECK THIS THREAD
FIXED/CHANGED
- Enabling/Disabling ports on MSTP could result in loss of connectivity
- updating VLANs port types was not registered with MSTP
ENHANCEMENTS
KNOWN ISSUES
- Some language templates need help - please private message Stephen Copeland to help
Released 3/30/2021
v1.5.7 Bug Reports and Comments
- Been thanked: 208 times
kkier - Member
Re: v1.5.7 Bug Reports and Comments
Upgrading from 1.5.0 (confirmed, possibly other firmware versions) to 1.5.7 breaks dropbear start.
Specifically from a reboot:
This version of dropbear identifies as dropbear sshd v0.53
It appears that the init script is trying to run this:
Note that the version of dropbear in 1.5.6 (which does recognize the -z argument) *also* identifies as v0.53.
- Code: Select all
Office_:/www# netstat -tulpn
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address Foreign Address State PID/Program name
tcp 0 0 127.0.0.1:4200 0.0.0.0:* LISTEN 657/shellinaboxd
tcp 0 0 :::80 :::* LISTEN 792/lighttpd
tcp 0 0 :::443 :::* LISTEN 792/lighttpd
udp 0 0 0.0.0.0:161 0.0.0.0:* 955/snmpd
udp 0 0 0.0.0.0:42417 0.0.0.0:* 692/syslogd
udp 0 0 :::161 :::* 955/snmpd
Office_:/www# /etc/init.d/dropbear start
Unknown argument -z
- Code: Select all
DROPBEAR_ARGS="${nopasswd:+-s }${port:+-p $port }${tarpit_attempts:+-z $tarpit_attempts }${tarpit_delay:+-T $tarpit_delay} ${log_logins:+-l }"
Users browsing this forum: No registered users and 108 guests
