Netonix Manager windows
sambo521
Mon Mar 22, 2021 3:12 pm
Looking on my util pc for a problem with another program I noticed that my Netonix Manager was not running. I started it and noticed that all the setups has been cleared and it was like it just got installed.
I had to go back in and repopulate all the information.
Its version is V4.9.1, is this the latest or what is the latest?
Also my wisp switch WS-6-POE firmware is V1.0.17 and probably needs updating but I hate to mess with it since its working.
Been thanked: 208 times
Re: Netonix Manager windows
Tue Mar 23, 2021 11:14 am
sambo521 wrote:Looking on my util pc for a problem with another program I noticed that my Netonix Manager was not running. I started it and noticed that all the setups has been cleared and it was like it just got installed.
I would need to see something like a syslog to be able find out why that may have occurred.
But possibly, if an update occurred on the PC or maybe Anti-VIrus software fluked then key files for the manager were erased.
sambo521 wrote:Its version is V4.9.1, is this the latest or what is the latest?
Well, the latest Netonix Manager is currently v1.0.17.
I can only guess you meant v1.4.9 for your WS-6-MINI version?
I guess practically speaking as long as it's working and you don't expect to make any changes to your network that might result in exposing bugs in that version then there's nothing to worry about. But you may want to note that the longer you wait, the more likely you will need to re-configure the switch after the update is applied (and indeed, if you are on 1.4.9 going to 1.5.7rcX, the switch will need to be re-configured)
Users browsing this forum: No registered users and 111 guests
