We have many 8 and 12 port DC Netonix switches and they report out current draw in Amps. However, the WS-26-DC does not. Have tried firmware 1.5.5 and 1.5.6 without success in this value reporting.
Has anyone seen this and found a fix?
WS-26-DC Switch Not Reporting Out Current Draw (Amps)
- tbuttrick
Re: WS-26-DC Switch Not Reporting Out Current Draw (Amps)
DC or IDC ?
From the IDC page: Does not allow monitoring of DC input voltage
https://netonix.com/wisp-switch/ws-26-400-idc.html
- tbuttrick
This model ?
https://netonix.com/ws-26-dc.html
Not sure but it seem it's a model without smart power supply and I think this stat is only available on model with smart power supply like following model:
https://netonix.com/wisp-switch/ws-26-500-dc.html
AFAIK, any switch that does not include the wattage in the model number does not have a power supply and as such is intended to be hooked to a regulated power source. As Mike said, it is the smart power supply that reports the out current draw.
- tbuttrick
Thanks to you both.
