one of our WS-12-DC behaves strange:
On port 3 power consumption is displayed at around 86W, but nothing is connected. This appears only when power "48H" is selected, otherwise power consumption is 0W. Ports 0-2 behave correct.
Cable diagnostics shows correct "open, 0 meters".
This is reproducable, everytime I switch to 48H power consumption goes up. At the power-tab total power consumption includes the power from port 3.
Factory reset does not help.
Firmware Version
1.5.6
Board Rev
F
Any ideas?
Regards
Thomas
power consumption on port (~86W) - bot nothing connected
- schorsch
- schorsch
Re: power consumption on port (~86W) - bot nothing connected
Netonix support team? Any ideas?
I am not part of the support team but can tell you have a damaged current sensor. Do you have any idea how it got damaged?
- schorsch
Not really, there have been 3 SIAE Alfo+ connected to the switch. The other ports are ok.....
