WS-8-150AC - Random Reboots?
sbyrd
Has thanked: 16 times
Been thanked: 26 times
Mon Jan 25, 2021 2:53 pm
I installed a WS-8-150AC on 12-10-2020 to replace a handful of POE bricks for UBNT APs.
Switch FW is 1.5.5.
I have it powering 5 RocketAC APs with average total power usage of the switch around 38-45W.
The switch is connected to a Digital Loggers Web Power switch for AC power.
Once today and once on 1-16-21 the switch and all the APs connected to the switch rebooted. The tower router (Mtik RB850Gx2), web power strip, and AF5X radio that are plugged into and powered off the web power strip do not lose power or reboot.
What should I be looking for as the cause? Is the switch crashing or faulty?
MrBook
Re: WS-8-150AC - Random Reboots?
Sun Nov 21, 2021 6:16 pm
Did you ever find the solution to this? I have the same thing going on. Updated from 1.5.5 to 1.5.8 hoping it resolves.
sbyrd
Thu Nov 25, 2021 8:51 am
Honestly I cannot remember what I ended up doing as I forgot to document the issues on 1-25-21 in our ticket system. I believe the switch is still in use and I have not had any issues since. However, this year on 4-24-21 I installed a AC inverter/charger with AGM battery backup system for the tower. Before this the tower had nothing but a surge suppressor power strip.
