Default vlan not striping tags?
jluczynski
Mon Jan 04, 2021 2:02 pm
Good day,
I have the vlans set up on the radio and changed the default to our management vlan. If we are connected locally to the netonix I have no access to the radios. If I connect to any other switch in the network I can get to the radios at these sites but not the switch.
I have changed the default vlan from 1 to 100 but it seems the switches are still broadcasting the Mac on vlans 1 to the radios even though we changed it? We believe the netonix isn’t using the vlan 100 correctly?
Been thanked: 208 times
Re: Default vlan not striping tags?
Mon Jan 04, 2021 2:52 pm
Please post your Status, Ports, and VLANs tab along with the switch log and let us know what firmware version you are using so we can try and help.
