v1.5.7rxX wrote:FIXED/CHANGED
- Enabling/Disabling ports on MSTP could result in loss of connectivity - RC2
- updating VLANs port types was not registered with MSTP - RC1
ENHANCEMENTS
KNOWN ISSUES
- Some language templates need help - please private message Stephen Copeland to help
RC2 Released 12/10/2020
RC1 Released 12/9/2020
v1.5.7rcX Bug Reports and Comments
- Been thanked: 207 times
JustJoe - Experienced Member
- Has thanked: 94 times
- Been thanked: 59 times
Re: v1.5.7rcX Bug Reports and Comments
The VLAN ID change seems to work now.
But the STP per port enable/disable still struggling
viewtopic.php?f=17&t=6787#p33880
See latest posts in that thread for details.
JustJoe wrote:The VLAN ID change seems to work now.
Updated that thread to report very good results with v1.5.7rc2. Unable to recreate any of those issues.
Is the TLS browser security issue addressed in this release?
Omniflux - Experienced Member
- Has thanked: 5 times
- Been thanked: 32 times
These are issues I've reported against earlier versions that still exist
NETONIX-SWITCH-MIB::dcdcEfficiency is missing the instance subidentifier (.0)
If an element is queried from a non existent table, it appears the next table is used for the reply instead of No Such Object.
This fills my NMS logfile with lines like
- Code: Select all
$ snmpget -v2c -c public -On 100.96.49.2 .1.3.6.1.2.1.2.2.1.6.3
.1.3.6.1.2.1.2.2.1.7.3 = INTEGER: up(1)
- Code: Select all
SNMP response from host "100.96.60.2" contains variable bindings that do not match the request: sent ".1.3.6.1.2.1.2.2.1.6.10", received ".1.3.6.1.2.1.2.2.1.7.10"
Added a new MSTP bug report:
viewtopic.php?f=17&t=6787&p=33984#p33984
This bug existed at least as far back as v1.5.6, but couldn't isolate & document it until now.
Kevo wrote:Is the TLS browser security issue addressed in this release?
No, it will be done before 1.5.7 is fully released though.
wtm - Experienced Member
- Has thanked: 41 times
- Been thanked: 36 times
Is the 802.3ad LAG issue going to be addressed. The switch will NOT do more than 2 LAG ports that are using the 802 standard. You must use the "rr balanced" mode for it to even work. This is a problem with 1.5.1 and later software.
wtm, I do intend to tackle the LAG issue before 1.5.7 is complete. There are a few things I have to do first though.
However, it might help to know that the WS3's 10G switches are available now which might help you circumvent the issue.
- bayamon
Any news on fixing LAG issues on Netonix?
Users browsing this forum: No registered users and 199 guests
