Problems logging in with Safari
Kevo
Has thanked: 3 times
Tue Oct 27, 2020 9:32 am
It seems some recent security update has changed something such that I can no longer log in to the web interface properly with safari on the mac.
The first error says the website has an outdated security configuration which may allow an attacker to steal ...
The further explanation says, Safari warns you when a website uses TLS 1.0 or 1.1 which are not secure.
It allows me to visit anyway after entering my computer password. Then after logging in to the wisp I get a blank page that reloads after a few seconds and that cycle seems to repeat over and over.
I can login fine with Firefox after going past the security warnings. Is this going to be fixed in an update soon? It is very annoying.
Thanks.
Been thanked: 210 times
Re: Problems logging in with Safari
Tue Oct 27, 2020 10:45 am
Noted, putting it on the list for the next major release.
bigal488
Wed Oct 13, 2021 7:45 am
Was this ever resolved? I can't log in to any of our Netonix using Safari 15 on OSX Big Sur. The login page loads (without logo) and logging in produces a blank page which endlessly reloads...
Older Safari and Google Chrome on OSX works as expected.
nzjimmy
Thu Oct 19, 2023 4:32 am
I'm seeing this now on Mac OS Catalina - any solution available?
Thanks.
sakita
Has thanked: 112 times
Been thanked: 90 times
Thu Oct 19, 2023 12:47 pm
What changed on the computer end? New Safari version?
What version firmware is on the switch? I've had older firmware versions flat out not work with updated browsers (requiring alternate methods to update the firmware - e.g. Netonix manager or login with SSH and pull firmware with FTP).
Even with 1.5.14 the certificate it uses for https will be considered untrusted but Chrome works after complaining about it.
With Firefox you can allow TLS downgrade to make it work (although there are security implications).
Users browsing this forum: No registered users and 17 guests
