I have some devices that don't like being powered off for only a short period. They like 30-60 seconds of rest time before being powered back on.
Is there a way to adjust the power-off duration used by the ping watchdog, and as used by the "Port Bounce POE" function on the Status page?
In the config.json file PingWatchdogs section I found the CutPowerFor parameter, and tried changing the default value of 10 to 50, but my change appeared to have no effect.
Adjust watchdog power-off duration?
- Been thanked: 208 times
Re: Adjust watchdog power-off duration?
At present, this is not possible, however it's not hard to implement I will add it to the todo list for the next release.
