WS-8-150-AC Does not display port wattage column?
wnoc - Member
Hi I went to look at a switch as I noticed a radio down, but noticed the switch was not displaying a column for Watts like the other switches do. I know you can click on every port and see the wattage at the top, but I was kind of wondering why it missing the column like every other netonix switch has? It also does not display the wattage either under the Power tab either. I also upgrade to the latest firmware too 1.5.6 just to make sure that was not an issue, but all the WS-8-150-AC I checked had the same thing.
1 post
