WS-8-150-DC No Throughput
ogryry
Mon Sep 21, 2020 6:44 pm
New install. Only used these a couple of times....
I made sure firmware was up to date then set static IPv4 info and enabled POE output voltage on appropriate ports. The switch does not appear to have any throughput; you can see it on the network but a device connected to any port will not get an IP address from the Antennae's DHCP server. If you bypass the switch it will.
I factory restored with no change. Any ideas?
Thanks,
Ryan
JustJoe
Has thanked: 94 times
Been thanked: 59 times
Re: WS-8-150-DC No Throughput
Mon Sep 21, 2020 8:30 pm
What version did yours ship with ?
If v1.5.5 then you need to read this thread:
viewtopic.php?f=17&t=6243
For most people with this problem, they need to download from this website and re-install the firmware.
v1.5.5 worked for most people.
Now the new v1.5.6 should also work.
ogryry
Tue Sep 22, 2020 6:29 pm
Well that was it. Shipped with 1.5.5. Reflashed 1.5.5 and all is good. How dumb. Thanks!
JustJoe
Tue Sep 22, 2020 7:27 pm
Glad that did it for you. :)
A little :thumbsup: never hurts. :wink:
Users browsing this forum: No registered users and 141 guests
