Firmware v1.2.0rc7 bug reports and comments
Sun Apr 12, 2015 12:56 pm
Please post comments and bugs for v1.2.0rc7 in this thread.
v1.2.0rc7 wrote:
FIXES
- Fixed several cosmetic requests
ENHANCEMENTS
- Firmware up-grader for DC power supply processor
KNOWN ISSUES
- Cable Diagnostic is broken
- Disabled ports shows lightening bolt instead of X
v1.2.0rc6 wrote:
FIXES
- Fixed scrolling on status page
- Fixed DHCP when changing the management VLAN ID
- Fixed SNMP stats for new models
- Fixed stats for new models in CLI
- Fixed problem with SFP ports not showing correct STP state on 12 port models
- Fixed problem configuring STP Priority
- Fixed MAC table sometimes showing filtered entries
- Ensure flashing 48VH PoE LED remains on during reboot
ENHANCEMENTS
- Added fallback to static IP configuration if DHCP fails
- Added DHCP Snooping
- Added Ubiquiti Discovery
- Added Cisco Discovery
- Added TFTP auto backup for config
- Added buttons to reorder VLANs
- Added support for WS-6-MINI, WS-8-250-DC, WS-12-250-AC and WS-12-250-DC
- Added Power tab for DC models
- Added current ratings to PoE settings in UI
- Added board rev to flash configuration
- Added CLI command to show vlans
- Added CLI command to change ID of VLANs
Re: Firmware v1.2.0rc7 bug reports and comments
Sun Apr 12, 2015 1:01 pm
I upgraded all my switches in service today with v1.2.0rc7 but this is not saying you should.
My switches were on several different versions as I used them as test beds but the oldest was v1.1.0.
All the upgrades went smoothly.
I would upgrade less critical switches first and play with it until you are satisfied, then put on production switches at your own discretion.
If you have any switches in service that are NOT v1.1.8 you NEED to upgrade them soon as there were some major bugs fixed in v1.1.7 and especially v1.1.8.
Sun Apr 12, 2015 1:16 pm
sirhc wrote:I upgraded all my switches in service today with v1.2.0rc7 but this is not saying you should...
I upgraded my WS24. Should I try this on the MINI?
Sun Apr 12, 2015 1:25 pm
Yes, 1.2.0 and up is for the newer models
Sun Apr 12, 2015 2:03 pm
OK, flashed the MINI. Watts still reporting the same. (yes, I know... not in the release notes).
Sun Apr 12, 2015 3:16 pm
lligetfa wrote:OK, flashed the MINI. Watts still reporting the same. (yes, I know... not in the release notes).
You should send an email to Eric and CC Dave on it.
computercolin
Mon Apr 13, 2015 5:31 pm
Tested the RSTP priority bug I reported earlier.
v1.2.0rc7 sends BPDUs with correct RSTP priority. Bug fixed! Good work, thanks guys!
