v1.5.6rcX Bug Reports and Comments
Been thanked: 208 times
Thu Jul 30, 2020 1:27 am
v1.5.6rcX wrote:FIXED/CHANGED
- NTP client refresh's it's connection at a regular interval
- added tooltip to "broadcast on protocols" discovery button
- CLI now shows DC values for WS-8-150-DC for command 'show status'
ENHANCEMENTS
- Latitude and Longitude sent with email from watchdog
KNOWN ISSUES
R1 Released 7/30/2020
R2 Released 8/6/2020
RemoteISP
Re: v1.5.6rcX Bug Reports and Comments
Fri Aug 07, 2020 3:15 am
Does this Update fix the voltage difference from the netonix to the "actual" voltage, these are 1V out and that is vital a few days a year in Australia.
i have photos of my tests if required. i'm running 1.5.5
Fri Aug 07, 2020 10:16 am
Are you measuring these values with SNMP?
Fri Aug 07, 2020 11:10 am
RemoteISP wrote:Does this Update fix the voltage difference from the netonix to the "actual" voltage, these are 1V out and that is vital a few days a year in Australia.
Which voltage are you talking about?
Please keep in mind that these components are not mil spec and all have a +/- variance.
Now on the SMART DC switches there is a calibration you can do to help make it more accurate on the input voltage.
Also most volt meters are also not all the same as we battle this all the time in the shop. If we need accurate measurements we have to use expensive equipment.
Also there is a 1V drop from the switch board input voltage to the POE output voltage when it comes to the 48V POE. Meaning if you feed the board 50V then the POE out is 49V this is not avoidable.
