Under Device > MAC Table, if I sort on port, it does it as an alpha sort not numerical, so: 1, 10, 11, 2, 20, 3, etc.
What is the secret to getting Last IP to show anything other than Unknown?
UI nit picking
Re: UI nit picking
lligetfa wrote:Under Device > MAC Table, if I sort on port, it does it as an alpha sort not numerical, so: 1, 10, 11, 2, 20, 3, etc.
Last known IP will be a trick when we release it, I am not aware of any Layer 2 switch that reports IP address?
Re: UI nit picking
I just now got around to cutting everything back over to the WS from the ES and so needed to lookup the MAC addies to update the description fields.
Re: UI nit picking
lligetfa wrote:I just now got around to cutting everything back over to the WS from the ES and so needed to lookup the MAC addies to update the description fields.
I do not think the ES reports IP, It might though since it is "technically" a Layer 3 switch since it can have up to what 8 or 9 static routes?
