WS-8-150-AC Not forwarding packets
JarrydD
Tue Jun 23, 2020 5:47 am
ImageGood day
I wonder if you can help me please, I am using a WS-8-150-AC connected to a Wireless Transmitter. I will often see the switch stops forwarding packets/frames however in the status the switch shows the exact same amount of data transmitted across the 4 ports I have wireless transmitters connected. This do not appear to be correct data as if does not show the mac's of the devices nor can I access them. I try bounce each port to no avail and have to reboot the entire switch for it to start forwarding packets again. I do not see how it could be a loop as they are separately connected to each Wireless device with no switch in between, see screenshot for the said problem:Image
Omniflux
Has thanked: 5 times
Been thanked: 32 times
Re: WS-8-150-AC Not forwarding packets
Tue Jun 23, 2020 12:06 pm
Is there anything showing up in the log?
