WS-12-250-AC Will not boot
totalhighspeed
Been thanked: 3 times
Wed Jun 17, 2020 9:54 am
Power on the switch, after a few minutes it gets a link light and then nothing. Both new out of the box and refurb units doing this.
Console output seems to hang at "i2c_vcoreiii i2c_vcoreiii: i2c bus driver on IRQ 19", full output below...
Code: Select all
Non-certified release, version 1_31-59b62e6 - built 10:54:13, Nov 10 2017
RAM: 0x80000000-0x88000000 [0x80028ec0-0x87fafffc available]
FLASH: 0x40000000-0x40ffffff, 256 x 0x10000 blocks
== Executing boot script in 1.000 seconds - enter ^C to abort
RedBoot> fis load -d linux
Image loaded from 0x80100000-0x8036422c
RedBoot> go
Linux version 2.6.26.8 (dev@netonixdev) (gcc version 4.1.2) #2 Thu May 31 15:57:15 EDT 2018
Determined physical RAM map:
Zone PFN ranges:
 Normal 0 -> 32768
 0: 0 -> 32768
Writing ErrCtl register=80008230
Readback ErrCtl register=80008230
Memory: 126052k/131072k available (1917k kernel code, 4840k reserved, 417k data, 116k init, 0k highmem)
net_namespace: 640 bytes
TCP reno registered
JFFS2 version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
msgmni has been set to 246
io scheduler noop registered
console [ttyS0] enabled
No NAND device found!!!
m25p80 spi0.0: m25q128 (16384 Kbytes)
mtd: partition "rootfs" set to be root filesystem
ip_tables: (C) 2000-2006 Netfilter Core Team
TCP cubic registered
lo: Disabled Privacy Extensions
ip6_tables: (C) 2000-2006 Netfilter Core Team
Freeing unused kernel memory: 116k freed
- preinit -
Press CTRL-C for failsafe
Resetting to factory defaults (default button pressed)
mounting jffs2
switching to jffs2
- init -
Please press Enter to activate this console. Jan 1 00:00:24 syslogd started: BusyBox v1.19.4
Jan 1 00:00:24 kernel: klogd started: BusyBox v1.19.4 (2018-06-01 19:38:44 EDT)
Jan 1 00:00:24 kernel: Linux version 2.6.26.8 (dev@netonixdev) (gcc version 4.1.2) #2 Thu May 31 15:57:15 EDT 2018
Jan 1 00:00:24 kernel: Invalid kernel arglist - use RedBoot "exec" command to boot kernel.
Jan 1 00:00:24 kernel: Using predefined kernel options.
Jan 1 00:00:24 kernel: CPU revision is: 02019654 (MIPS 24K)
Jan 1 00:00:24 kernel: Determined physical RAM map:
Jan 1 00:00:24 kernel: User-defined physical RAM map:
Jan 1 00:00:24 kernel: memory: 08000000 @ 00000000 (usable)
Jan 1 00:00:24 kernel: Entering add_active_range(0, 0, 32768) 0 entries of 256 used
Jan 1 00:00:24 kernel: Zone PFN ranges:
Jan 1 00:00:24 kernel: Normal 0 -> 32768
Jan 1 00:00:24 kernel: Movable zone start PFN for each node
Jan 1 00:00:24 kernel: early_node_map[1] active PFN ranges
Jan 1 00:00:24 kernel: 0: 0 -> 32768
Jan 1 00:00:24 kernel: On node 0 totalpages: 32768
Jan 1 00:00:24 kernel: Normal zone: 256 pages used for memmap
Jan 1 00:00:24 kernel: Normal zone: 0 pages reserved
Jan 1 00:00:24 kernel: Normal zone: 32512 pages, LIFO batch:7
Jan 1 00:00:24 kernel: Movable zone: 0 pages used for memmap
Jan 1 00:00:24 kernel: Built 1 zonelists in Zone order, mobility grouping on. Total pages: 32512
Jan 1 00:00:24 kernel: Kernel command line: console=ttyS0,115200 init=/etc/preinit mem=128M
Jan 1 00:00:24 kernel: Primary instruction cache 32kB, VIPT, 4-way, linesize 32 bytes.
Jan 1 00:00:24 kernel: Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Jan 1 00:00:24 kernel: Writing ErrCtl register=80008230
Jan 1 00:00:24 kernel: Readback ErrCtl register=80008230
Jan 1 00:00:24 kernel: Cache parity protection enabled
Jan 1 00:00:24 kernel: PID hash table entries: 512 (order: 9, 2048 bytes)
Jan 1 00:00:24 kernel: Dentry cache hash table entries: 16384 (order: 4, 65536 bytes)
Jan 1 00:00:24 kernel: Inode-cache hash table entries: 8192 (order: 3, 32768 bytes)
Jan 1 00:00:24 kernel: Memory: 126052k/131072k available (1917k kernel code, 4840k reserved, 417k data, 116k init, 0k highmem)
Jan 1 00:00:24 kernel: SLUB: Genslabs=6, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Jan 1 00:00:24 kernel: Calibrating delay loop... 277.70 BogoMIPS (lpj=1388544)
Jan 1 00:00:24 kernel: Mount-cache hash table entries: 512
Jan 1 00:00:24 kernel: net_namespace: 640 bytes
Jan 1 00:00:24 kernel: NET: Registered protocol family 16
Jan 1 00:00:24 kernel: NET: Registered protocol family 2
Jan 1 00:00:24 kernel: Switched to high resolution mode on CPU 0
Jan 1 00:00:24 kernel: IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
Jan 1 00:00:24 kernel: TCP established hash table entries: 4096 (order: 3, 32768 bytes)
Jan 1 00:00:24 kernel: TCP bind hash table entries: 4096 (order: 2, 16384 bytes)
Jan 1 00:00:24 kernel: TCP: Hash tables configured (established 4096 bind 4096)
Jan 1 00:00:24 kernel: TCP reno registered
Jan 1 00:00:24 kernel: squashfs: version 3.0 (2006/03/15) Phillip Lougher
Jan 1 00:00:24 kernel: Registering mini_fo version $Id$
Jan 1 00:00:24 kernel: JFFS2 version 2.2. (NAND) (SUMMARY) �© 2001-2006 Red Hat, Inc.
Jan 1 00:00:24 kernel: msgmni has been set to 246
Jan 1 00:00:24 kernel: io scheduler noop registered
Jan 1 00:00:24 kernel: io scheduler deadline registered (default)
Jan 1 00:00:24 kernel: Serial: 8250/16550 driver $Revision: 1.90 $ 1 ports, IRQ sharing disabled
Jan 1 00:00:24 kernel: serial8250.0: ttyS0 at MMIO 0x70100000 (irq = 14) is a 16550A
Jan 1 00:00:24 kernel: console [ttyS0] enabled
Jan 1 00:00:24 kernel: No NAND device found!!!
Jan 1 00:00:24 kernel: m25p80 spi0.0: m25q128 (16384 Kbytes)
Jan 1 00:00:24 kernel: Mapped SPI read area @0x40000000 len 16777216
Jan 1 00:00:24 kernel: Creating 10 MTD partitions on "m25p80":
Jan 1 00:00:24 kernel: 0x00000000-0x00040000 : "RedBoot"
Jan 1 00:00:24 kernel: 0x00040000-0x00080000 : "config"
Jan 1 00:00:24 kernel: 0x00080000-0x001c0000 : "linux_recovery"
Jan 1 00:00:24 kernel: 0x001c0000-0x003c0000 : "rootfs_recovery"
Jan 1 00:00:24 kernel: 0x003c0000-0x00500000 : "linux"
Jan 1 00:00:24 kernel: 0x00500000-0x00b00000 : "rootfs"
Jan 1 00:00:24 kernel: mtd: partition "rootfs" set to be root filesystem
Jan 1 00:00:24 kernel: 0x00b00000-0x00f40000 : "rootfs_data"
Jan 1 00:00:24 kernel: 0x00f40000-0x00f80000 : "FIS directory"
Jan 1 00:00:24 kernel: 0x00f80000-0x00f81000 : "RedBoot config"
Jan 1 00:00:24 kernel: 0x00fc0000-0x01000000 : "Redundant FIS"Jan 1 00:00:24 kJan 1 00:00:24 Jan 1 00:00:24 Jan 1 00:00:24 Jan 1 00:00:24 vtss_cor.
i2c /dev entries driver
Any suggestions?
Users browsing this forum: Majestic-12 [Bot] and 39 guests
