SMTP incorrect behavior - HELO identification
jpaine619
Has thanked: 26 times
Been thanked: 18 times
Sun Jun 07, 2020 5:21 am
Can someone at Netonix explain why the switch, when running the SMTP test, connects to the remote SMTP server and identifies itself as that server?
i.e. If I have (just as an example) the HOST set to 1.1.1.1, when I run the SMTP test, the switch will connect to 1.1.1.1 and then issue a "HELO 1.1.1.1".
This is absolutely incorrect behavior. The switch should not be identifying ITSELF as the remote server in the HELO string. One of the easiest ways to cut down on spam is to drop the connection from any remote client identifying itself as the server in the HELO string.
There is a setting for "Local Hostname", but the switch is not using it. To wit, if I have "switch.example.com" set in the "Local Hostname" field, then the Netonix SHOULD issue a "HELO switch.example.com"
I'm currently running firmware 1.5.5.
If y'all need, I can provide logs and screenshots to show you what I'm talking about, but I'd rather not post them publicly.
Been thanked: 207 times
Re: SMTP incorrect behavior - HELO identification
Mon Jun 08, 2020 2:32 pm
Please send me the relevant logs in a PM.
jpaine619
Wed Jul 01, 2020 6:42 am
Any luck on resolving this?
jpaine619
Fri Nov 20, 2020 5:29 pm
Okay.. 5 months now.. All evidence provided that the switch is acting incorrectly with regard to RFCs and still no word on if this is going to be fixed...
RFC's were cited and full logs were provided in a private message
Fri Nov 20, 2020 7:40 pm
It will be fixed. But it is presently a lower priority issue until the new product release.
Users browsing this forum: No registered users and 16 guests
