How to Reboot from Command Line
konspiracy
Tue May 19, 2020 8:26 pm
WS-12-250-AC
How would you reboot this switch from the command line. We have been having issues at a couple different sites where the netronix is able to be accessed from the management Ip but it gets hung up and all traffic stops. Once we manually unplug the device and plug it back on we can resume service. To save us from driving to these remote locations it would be nice if we can reboot it from the command line after ssh into it.
Thanks,
Shane
Edit: The issue we are having is stated above, randomly during typically normal conditions, the AP's go down and we lose connection to them. We can access our Mikrotik in front of the netronix, and we can log into the netronix but Lightpd fails if you try to back up the config or make changes. You can ssh into them, cmdline and restart lightpd, but it will not fix your issue. I have tried everything and the reboot script has been altered and its super frustrating.
Re: How to Reboot from Command Line
Tue May 19, 2020 9:23 pm
reload cold
or
cmdline
reboot
