Information about MACs from SNMP
Ludvik
Has thanked: 15 times
Been thanked: 15 times
Sat May 16, 2020 2:53 am
Hi.
I am trying to search MAC addresses in Netonix switch with SFP ports (type and firmware version doesn't matter).
Table 1
.1.3.6.1.2.1.17.4.3.1.1.1 = Hex-STRING: EC 13 B2 61 DE 4E
.1.3.6.1.2.1.17.4.3.1.1.2 = Hex-STRING: 00 27 22 A4 1A 03
.1.3.6.1.2.1.17.4.3.1.1.3 = Hex-STRING: 24 A4 3C 00 DD 14
.1.3.6.1.2.1.17.4.3.1.1.4 = Hex-STRING: 24 A4 3C 6E 43 38
.1.3.6.1.2.1.17.4.3.1.1.5 = Hex-STRING: 24 A4 3C 6F 43 38
.1.3.6.1.2.1.17.4.3.1.1.6 = Hex-STRING: 6C 3B 6B 84 71 6D
.1.3.6.1.2.1.17.4.3.1.1.7 = Hex-STRING: 00 27 22 F6 02 41
Table 2
.1.3.6.1.2.1.17.4.3.1.2.1 = INTEGER: 0
.1.3.6.1.2.1.17.4.3.1.2.2 = INTEGER: 6
.1.3.6.1.2.1.17.4.3.1.2.3 = INTEGER: 6
.1.3.6.1.2.1.17.4.3.1.2.4 = INTEGER: 6
.1.3.6.1.2.1.17.4.3.1.2.5 = INTEGER: 6
.1.3.6.1.2.1.17.4.3.1.2.6 = INTEGER: 26
.1.3.6.1.2.1.17.4.3.1.2.7 = INTEGER: 26
Last oid number in Table1 is index to Table2. Integer value in Table2 is physical port number.
Problem is simple: this is from WS-12. Port number bigger than 14 doesn't exists. I think you have wrong numbering SFP ports in this table.
Other snmp tables are fine. Ports numbers are 1-14.
Proof:
.1.3.6.1.2.1.2.1.0 = INTEGER: 14
.1.3.6.1.2.1.2.2.1.1.1 = INTEGER: 1
.1.3.6.1.2.1.2.2.1.1.2 = INTEGER: 2
.1.3.6.1.2.1.2.2.1.1.3 = INTEGER: 3
.1.3.6.1.2.1.2.2.1.1.4 = INTEGER: 4
.1.3.6.1.2.1.2.2.1.1.5 = INTEGER: 5
.1.3.6.1.2.1.2.2.1.1.6 = INTEGER: 6
.1.3.6.1.2.1.2.2.1.1.7 = INTEGER: 7
.1.3.6.1.2.1.2.2.1.1.8 = INTEGER: 8
.1.3.6.1.2.1.2.2.1.1.9 = INTEGER: 9
.1.3.6.1.2.1.2.2.1.1.10 = INTEGER: 10
.1.3.6.1.2.1.2.2.1.1.11 = INTEGER: 11
.1.3.6.1.2.1.2.2.1.1.12 = INTEGER: 12
.1.3.6.1.2.1.2.2.1.1.13 = INTEGER: 13
.1.3.6.1.2.1.2.2.1.1.14 = INTEGER: 14
.1.3.6.1.2.1.2.2.1.2.1 = STRING: Port 1
.1.3.6.1.2.1.2.2.1.2.2 = STRING: Port 2
.1.3.6.1.2.1.2.2.1.2.3 = STRING: Port 3
.1.3.6.1.2.1.2.2.1.2.4 = STRING: Port 4
.1.3.6.1.2.1.2.2.1.2.5 = STRING: Port 5
.1.3.6.1.2.1.2.2.1.2.6 = STRING: Port 6
.1.3.6.1.2.1.2.2.1.2.7 = STRING: Port 7
.1.3.6.1.2.1.2.2.1.2.8 = STRING: Port 8
.1.3.6.1.2.1.2.2.1.2.9 = STRING: Port 9
.1.3.6.1.2.1.2.2.1.2.10 = STRING: Port 10
.1.3.6.1.2.1.2.2.1.2.11 = STRING: Port 11
.1.3.6.1.2.1.2.2.1.2.12 = STRING: Port 12
.1.3.6.1.2.1.2.2.1.2.13 = STRING: Port 13
.1.3.6.1.2.1.2.2.1.2.14 = STRING: Port 14
It is impossible to work with it without "hacks" based on switch type. It is firmware error, i think.
Been thanked: 208 times
Re: Information about MACs from SNMP
Mon May 18, 2020 4:16 am
Hey Ludvick, yes this is a firmware error. I will look into it.
Users browsing this forum: No registered users and 26 guests
