WS-12-250-AC thinks it is a WS-12-250-DC
muhamad90
Tue May 12, 2020 10:18 pm
The title pretty much sums up my issue. Just installed a new WS-12-250-AC, and it is showing up in the GUI, and Netonix manager as an DC. Upgraded to 1.5.5 with no change.
Any ideas?
Been thanked: 208 times
Re: WS-12-250-AC thinks it is a WS-12-250-DC
Tue May 12, 2020 11:30 pm
Yeah I can fix that for you. If you can give me access to a computer that has an RS232 (serial cable) connection to this switch with PuTTY and a TeamViewer connection. I can fix it in about 10 minutes. Private Message me so we can setup a time that is convenient.
muhamad90
Fri May 15, 2020 11:00 am
thanks a lot Stephen
you solved the problem in minutes
Fri May 15, 2020 1:17 pm
I'm glad I could help muhamad90.
