Need base config/backup for WS-12-250-AC
markbreen
Tue Apr 28, 2020 4:13 pm
Hi, I messed up my WS-12-250-AC config by uploading the wrong backup file.
Does someone have a backup ncfg file they can send me that will set it back to how it came out of the box? Thanks so much in advance.
Mark
markbreen
Re: Need base config/backup for WS-12-250-AC
Tue Apr 28, 2020 4:59 pm
or any WS-12-250-AC config would work if you don't mind sharing yours
Been thanked: 208 times
Tue Apr 28, 2020 5:00 pm
Probably the easiest thing to do would be to just default the switch. Keep in mind it will go back to 192.168.1.20 but you can reconfigure it as you need from there.
On the web UI just go to Utilities->Default or over ssh or from a serial cable run the command
Code: Select all
reload defaults
markbreen
Tue Apr 28, 2020 5:07 pm
duh, thank you so much!
Wed Apr 29, 2020 2:48 am
You're welcome.
